Hi, new to forum,looking forward to picking out up some skills and info on how to be a competent welder, can somebody tell me if putting a knife switch on the earth for a lift arc machine would be the same as breaking the torch lead as Jody does with his foot pedal? Thanks and regards George
The switch will arc. Won't last long. Remote machines have both switch and potentiometer so as the control is turned off, the current goes to a minimum. Inverter machines use IGBT (a type of transistor or electronic switch) so arcing isn't an issue. Yes, they get hot.
Breaking the workpiece connection under load could be dramatic. As in a nasty arc flash.
I want to make a Wood Board/Knife Switch Foot Pedal (simple 220V On-Off Switch) like Jody built, for Lift Arc on my converting Stick welder.
I have the high Freq Box. Geting an Air Cooled torch. Need the foot switch to start weld and shut it back off at the end of the bead while allowing the gas to still flow.
What kind of knife switch did you buy/use?
Any pictures would be VERY helpful.
Stew
Stew
