i just purchased 2 weeks ago the foot pedal (7 pin connector) for my welder and i have a few questions.
i use pulse almost every time i weld ..so when i use pulse ..i don’t get any amperage control, it’s just like when i use the torch switch, ON-OFF effect. Is this normal? this is the way it works?
i only get amperage control when i don‘t use pulse, i set the amperage on the machine at let’s say 90 amps maximum ..and with the pedal i start and increase my amps or decrease if needed.
On the pedal i have an max current adj. nob ..from 1 to 10
i keep it at 8-9 when i use it.
Please if there are any tips in using the foot pedal ..enlighten me
