That looks to be a CK-type gas lens. Not "cleanable" or "rebuildable" in my experience. Worth driving a small nail into the wall and hanging that on it as a reminder to yourself for years to come.
Gas lenses are "consumables". Buy a 4 pack in 3/32 and 1/8. You'll need them. You might also increase your CFH from 10 to 15-18. And try some of the shorter, stubby cups. I find them easier for new welders to "manipulate" since their hand is closer to the surface then those "Yardstick cups".
Full disclosure: I have blasted perfectly ground tungstens in absolutely new lenses on more than 1 occasion. All set up to do some quality work that requires high amps, and the appearance/weld matters. Set my box up, fresh clean gloves, everything wiped down. Stomp the pedal blasting out 180 amps and WHAMMO! No gas. FCXUK! Tungsten explodes, gas lens looks like a road in Beirut, collet warped, material damaged.
So it will happen to you because it does happen to everyone at some point. Buy spares.
