I already asked one the following questions in my introduction, but I assume introductions are not read by everybody.
So I try it here again:
#1
On my machine I can adjust AC balance from 1-10:
1=95% negative
5=50% negative
10=5 % negative
So far, I was welding aluminum at around '3', meaning ~70% negative, 30% positive. Seems to be a kind of standard setting.
What about this '10' setting with only 5% negative and 95% positive? I did not try it yet and never saw any recommendation going that high with the cleaning action. Is there any practical use for this setting?
#2
I got a used 17 style torch set to replace my heavy 26 "bulky European style".
Before first trying it out, I wanted to check if there are any leaks. So clogged the ceramic with my thumb and turned on the Argon flow. For maybe 1s it seemed to hold the increasing pressure, then there was some leakage at the white insulation ring.
Actual welding went ok, I like the smaller torch a lot.
But still, I was wondering how tight the whole gas setup has to be. Is it ok for a torch to leak if the pressure rises considerably, or should it really hold the full outlet pressure of the regulator when I clog the ceramic?
BR,
Bossler
