Even more impressive!GreinTime wrote:The whole thing was done consecutively alternating joint to joint. I think it's 4" sections maybe?Oscar wrote:The titanium came out nice! Sucks having to wait for it to cool down though.
- GreinTime
Those are done with a Dynasty 350 inverter. I'd like to try one with a Syncrowave, just for shits and giggles.dunkster wrote:Super nice consistency on the coolers there Sam!....inverter or transformer machine?
Nice TI work as well....jealous.
- GreinTime
I don't pay for argonOscar wrote:Even more impressive!GreinTime wrote:The whole thing was done consecutively alternating joint to joint. I think it's 4" sections maybe?Oscar wrote:The titanium came out nice! Sucks having to wait for it to cool down though.
what do you do when work is slow and nothing to do for a few hours, you bend and weld up a brushed stainless mailbox to replace the broken plastic one that was on a rotting pole leaning into your driveway... and throw a quick name letter on it in the last 5 minutes of the day using the notcher and a cut off blade on the grinder... of course the rental house is still nasty but there's a nice shiny mailbox! ha...
Looks nice!raticus wrote:what do you do when work is slow and nothing to do for a few hours, you bend and weld up a brushed stainless mailbox to replace the broken plastic one that was on a rotting pole leaning into your driveway... and throw a quick name letter on it in the last 5 minutes of the day using the notcher and a cut off blade on the grinder... of course the rental house is still nasty but there's a nice shiny mailbox! ha...
Looks good, welds and fab work!Warrenh wrote:
This is a remodel of a poling platform. The customer bought a new motor with a jack and the platform had to be elevated 12 inches. I also had to add steps in the front due to the width of the fiberglass top.
- 5th Street Fab
- MosquitoMoto
- 5th Street Fab
the welding process is smaw (stick) we use 7018 for the vessel. This weld is a code or stamped weld it will be QCed under 31.12 boiler code ( no under cut or any indication while they pt it) and stamped with ASME stamp .after that we will hydro the tank to 300 psi twice the stamped pressure. This vessel is apart of a water treatment plant for a power house. Definitely not glamorous but I love what I do and being challenged every day and pushed to weld at a very high standard has put me and a very fortunate situation!Coldman wrote:Maybe not glamorous to you but involves serious skill and experience. Good job!
Now you have to elaborate on process and procedure used please.
Had to repair some dirty old stainless can't always be weldporn with new material at a bench. There is something satisfying about welding all curled up like a pretzel.
I couldn't get to the backside of this weld really good to clean a couple spots gave me issues.
- All ground out
- IMG_20170703_103237349.jpg (25.23 KiB) Viewed 4988 times
- IMG_20170703_112641899.jpg (24.54 KiB) Viewed 4988 times
- IMG_20170703_133703977.jpg (21.93 KiB) Viewed 4988 times
We all know that's true, good work as always RickRick_H wrote:Had to repair some dirty old stainless can't always be weldporn with new material at a bench. There is something satisfying about welding all curled up like a pretzel.
Bingo wrote:Well on this Friday we get back in our tig rigs 4" sch 40 70s6 ( not my favorite wire for carbon) welding under code 31.3
Nice work, I prefer 70s2 if allowed personally.
Making a new turbo back system for my MK4 TDI, 3" dp, 3" straight system....and I know you guys are shocked it's stainless and sanitary welded.
- IMG_20170707_112251881.jpg (43.72 KiB) Viewed 5521 times
- IMG_20170707_112225483.jpg (40.09 KiB) Viewed 5521 times
Yeah there was no way I was going to pay near $300 for a DP, I actually don't have a ton of money in everything front to back. I bought some fittings from Andron Stainless, if I knew how to pie cut or.could easily cut those at home I would have saved even more. It's been fun...have to mock it up today to get the angle of the DP right and make the middle section....then just weld it and add hangers. I used a 2"-3" reducer at the flange so I'd have bolt clearance, and a Vibrant Flex joint.hey_allen wrote:Only until he fires it up...Bingo wrote:Clean!![]()
I'm going to have to work on my pipe welding, I want one for my TDI, but can't stand the thought of paying what the commercial offerings are asking!
- GreinTime
Prototype done for the 10th Gen Civic Intercooler and Charge Pipe setup.
First time welding cast with 5356, can't say I'm really a fan. I don't know if I'll get to weld anymore of these, but we'll see if I can weld one with 5356, 4043, and 4943 back to back to back (batch work is nice for testing some times) with identical settings and see who can tell what!
