Requirements:
TIG with 250+ amps
Possibly 3 phase power supply
Budget of 3k (maybe 3.5k)
Hi, I'm the owner of a small manufacturing plant and I'm looking for a tig welder for equipment maintenance and some small fabrication projects. I do not have welding experience but I feel the investment in learning will pay off compared to the costs of transportation and the hiring of a welding shop, which adds up quickly. Max metal will be 4x4 carbon steel and stainless steel frames, and 3/8" (possibly 1/2") aluminum.
I have tons of power in the facility. 2000+ amps on the mains and 240V 3phase, 480v 3phase so power supply compatibility is not an issue.
I have a budget of under $3000 for a TIG. Bear in mind that this is not something we'll be using everyday, just special projects every couple weeks.
Been looking at Everlast 250EX & Longecity 250EX.
Due to so much conflicting reports on those from forum posters across the years, I was also looking at maybe a Lincoln Precision 275, or Miller Dynasty 280. Both those are about 1000 out of my budget. And these days just cause something says Made in America, it doesn't really mean much anymore...most of the components are overseas and the the Made-in-American durability ain't what it used to be.
Been scouring the local craigslist as well for equipment as well but nothing's been popping up for about a month already. Not too thrilled about used options on Ebay since most of those seem like auction houses or with little guarantee that they'd work.
I kind of feel like with all the power capacity I have I should be getting something to take advantage of the 240 or 480 3phase rather than running off of single phase inverter technology, but there doesn't seem to much available in this space - at least where I'm searching.
Any suggestions on what to buy?
Hmmmm! Decisions.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Farmwelding
- Farmwelding
Depending on your location I'd be looking around on Craigslist or auctions for a similar tig welder to what you want. A company may be going out of business or upgrading and then they sell or a tech school may be upgrading and selling everything they have. Keep keeping a look out. I would reccomend something like a dynasty 280. I've used them and they are some of the nicest machines I've used. I don't know if you've thought of it but you are probably going to want a water cooler as well for that size of a machine. That adds to the cost. Whatever you do, don't cheap out.
Instagram: @farmwelding
Nick
Nick
Everlast 255ext and Powercool W300 TIG torch cooler $2,650 delivered with free shipping directly from Everlast how can you top that? Leaves you $350 left over for gas, tungsten, filler rods.
I'm not a fan of the 'ex' vs the 'ext'. On the 'ex' there's so many knobs they can't really add any new features there's no space left. The control panel on the 'ext' works great, plus freed space for some additional features.
Miller? Lincoln? I can afford any damn welder I want, naturally I was on that Miller Dynasty 280dx package like flies on...until I called Miller. Aware of how many previously Made in USA products are now made in China and only assembled in the USA, and how companies don't really advertise that fact for obvious reasons. I called Miller and asked them about the Dynasty, yeah the guts are made in Asia and its only assembled and tested in the USA. I could not see paying more than double for it vs the Everlast. As for Lincoln don't get me started on them.
Now if the welder was mission critical, if I needed support immediately or my business was hemorrhaging money, then Miller by a mile. You can get same day support if you need it, you won't have that with an Everlast. Just trying to be fair to Miller that's worth a lot depending on how you are using the welder in your business.
If you're anywhere near the far west Chicago suburbs, this Miller Synchrowave on craigslist seems like exactly what you're looking for. I've been looking for a used tig machine and noticed this today.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
Lincoln 225 AC/DC
It goes in streaks, you'll find exactly what you're looking for the day after you buy something else.scorpion! wrote: Craigsilst is dry here
Lincoln 225 AC/DC
Lincoln 225 AC/DC
That's a great machine. If it's hours and cycles are low, that's also an excellent price. The machine will tell you it's number of arc hours, and it's number of arc starts. How to do this is in the manual, available on page 48 of this:LtBadd wrote:Actually there is a Miller Syncrowave 250DX listed for $2750, it's in Palm Harbor.scorpion! wrote:Sorry, guess I should have added that I'm in Tampa FL
https://www.millerwelds.com/files/owner ... AT_MIL.pdf
Page 52 of 68, as I received the .pdf
Poleframer
- Poleframer
Considering your price range, and that you are looking for a used industrial type machine at that, I'd think of looking farther afield, and more for shipping/freight. 3 phase motors and such often go cheap out there, but the buyers arent hobby guys. Might think more along the lines of 1500-2000 machine cost, and 500 to truck it there. Or factor in bare machine and add the cost of accessories.
Big upside for the Synchrowave is its Multi-process capable too. MIG, Stick and SpoolgunOtto Nobedder wrote:That's a great machine. If it's hours and cycles are low, that's also an excellent price. The machine will tell you it's number of arc hours, and it's number of arc starts. How to do this is in the manual, available on page 48 of this:LtBadd wrote:Actually there is a Miller Syncrowave 250DX listed for $2750, it's in Palm Harbor.scorpion! wrote:Sorry, guess I should have added that I'm in Tampa FL
If you want large power for cheap, Miller 330 abp tops out around 470 amps, goes down to 5 amps.
Single phase, use well over 100 amps at max power (60 amps in the mid range), sell often for $500-$1000.
Mine is painted orange, listed as an Airco 300, 900 lbs of 1963 awesome
Made into the 90's as I recall, durable and work great.
I recently bought a 90's Miller Syncrowave 350. Doesn't actually weld any better but the adjustable balance is nice.
If I remember correctly, running a spool gun is a new thing that started with the Syncrowave 210.cj737 wrote: Big upside for the Synchrowave is its Multi-process capable too. MIG, Stick and Spoolgun
You are correct, but my referral was to a new unit. Probably confusing that I linked it within a "Used Available" machine. Sorry for that-MinnesotaDave wrote:If I remember correctly, running a spool gun is a new thing that started with the Syncrowave 210.cj737 wrote: Big upside for the Synchrowave is its Multi-process capable too. MIG, Stick and Spoolgun
Just for the Syncrowave 210 though.cj737 wrote:You are correct, but my referral was to a new unit. Probably confusing that I linked it within a "Used Available" machine. Sorry for that-MinnesotaDave wrote:If I remember correctly, running a spool gun is a new thing that started with the Syncrowave 210.cj737 wrote: Big upside for the Synchrowave is its Multi-process capable too. MIG, Stick and Spoolgun
The 250/350 do not run spool guns that I've seen, what model year did that start?
Not long ago I sold a mint Miller Sycrowave 351 and cooler on Austin, TX craigslist like the one Mark found in the Chicago area. It was/is a beast of a machine built like a tank at over 500 lbs. I mainly sold it due to the space it consumed, a desire for features only inverter welders offer, portability, and a worry that a fix involving parts such as board might become unavailable soon. I have since purchased an Everlast 255ext new and a Miller Dynasty 200DX on craigslist. I still miss that 351 though as it was so precise down real low and powerful at 350 amps which I rarely needed. Everything about that machine was USA made and top quality for a transformer based platform.
Hey guys
Thanks for all the responses. I'm overwhelmed at how many people replied and offered helpful suggestions. It gave me a bit of thinking to do and some accompanying research.
I think I originally suggested a Sychrowave because I thought to myself, I have all this power available, why not take advantage of it. After more consideration there's really no advantage to running directly from the power supply rather than using an inverter. And I think a smaller unit might even be preferable. The reason being is that I have some big machines that can't be moved to a workshop - a 10,000lb blender, etc - and have to bring the welder there. I think moving a Dyansty or Everlast is a much more enjoyable task than moving the synchro
So now it's done to either a Dynasty 280 or Everlast 250. I would need the full kit. The Dynasty kit is around 6500-7000 vs the everlast which is around 3000.
I obviously prefer to spend 3k instead of 7k, but I can afford the 7k if I will really obtain that much more value from it.
I'm not going to be using it daily - probably a couple hours every few weeks. My biggest concern is that if something breaks, I can get it repaired within 1-2 weeks.
I guess I'm asking for a face-off between the Everlast v Dynasty because although Miller is a USA company my understanding is that much of the Dynasty is made overseas - maybe even the same plant as the Everlast? So do I really get a 100% more value with the Dynasty?
Thank you!
Thank you!
How can you measure value?
Miller power sources are used industrially day in year out. If there's a problem an authorised repairer usually isn't too far away with parts or access to parts quickly. Warranty repairs usually go smoothly, past warranty repairs go smoothly and fast as well.
Everlast power sources have to be posted back to them for warranty repair and also (correct me if I am wrong here) for post warranty repair because that's where the parts are at. Big down time. Also I still have not really heard from anyone using them industrially day in and year out. We've heard from some that have one for a couple of years and use it every week but not those that bash it all day every day year in year out so longevity is still not answered in my mind.
In my opinion, Everlast and Dynasty are not even in the same class to be compared...scorpion! wrote:Hey guys
Thank you!
I won't even buy a cheap used Everlast.
But I don't mind at all buying 2 cheap, used, high quality, tested design machines.
All my machines of every type, including a few I bought new, don't add up to $7000 and I have a lot of choices to weld with for any situation.
Don't get me wrong, if I had $7000 and wanted one, I'd buy the dynasty 280 and smile every time I used it
Farmwelding
- Farmwelding
Like Dave said-there is no comparison. I've used a dynasty 200,210, 280, and 350 and I'll tell you what-those are some of the nicest arcs on the market in my opinion. I've ran mostly AC tig on them and it was so nice. Recently I got to run stick on a dynasty 200 and precision tig 275- that dynasty is now my favorite machine. It was just so smooth and problem free. I was overly impressed that when I stuck the rod, the machine stopped sending electricity-maybe it is normal, but I'm use to an old buzzbox. I would spend the money on a dynasty.
Nick
Nick
The Dynasty is a benchmark TIG box. No 2 ways around it. Whether you require the amps from a 280 vs a 210 is the real question, and thats about a $2,000 question. If you will seldom use AC TIG on very thick aluminum, the 210 will perform nearly every function equally well. Even if you encounter some thick ally, a preheat will often get you through.
If I could afford it, sure, I'd buy the 280 and love myself for the next decade. But that $2k savings will pay for a very nice MIG box because the Dynasty is TIG/Stick only. I have a 2005 Dynasty 200Dx, and it still welds like day 1. I've invested $400 in it over that time for a replacement power relay and was without the box for 3 days at a local shop. Hard to beat that performance record and it has proved to me the brand is worth their reputation.
I'd look for a good ole Syncrowave 250 new or used, Iv'e had a couple of those and they are nearly bullet proof...
Pete
