    Thu Dec 25, 2014 9:25 am
    near Chicago
Otto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
:lol: TLAR....I'm gonna steal that from you ;)
Be my guest! I also estimate time on task by the WAG method, which is "Wild-Ass Guess". I always look like a hero, because I use Thomas Edison's rule... However long I think it will take, I double it, then add ten percent, and that's what I tell them.
Under-promise and over-deliver, and they'll beat down your door.
I use the Edison method as well! I just didn't know that's what it was called. :D
    Wed Mar 11, 2015 9:13 am
    All around Lake Pontchartrain
It's been a while since I posted anything substantial.
First time on 304 SS 1 1/2", 1" and 1/2" sch 40. Two passes. Argon purge at 10cfh. 3/32 2%Thoriated with #7 cup (wishing it was an 8).
Chris
AWS D1.1, D17.1
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
Getting the hang of these exhaust flex sections! 3" 304, backpurge at 7cfh, welded at 90a w/ 1/16"308L. Pictures arranged chronologically from out of the bag to welded, for those of you who have never had the unfortunate pleasure of welding one! ImageImageImageImage
    near Chicago
Great job Sam! I know you like bells and whistles...did you pulse these? You got great color.
    Pittsburgh, PA
exnailpounder wrote:Great job Sam! I know you like bells and whistles...did you pulse these? You got great color.
No, these guys are anti pulse lol. I welded 1/2-5/8" at a time, mainly because that outer shell is 0.020-0.030" thick in some places. Monster 16 nozzle at 40-45cfh. I don't remember if I included that bit.
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
Very nice work, Sam.
K
    Mon Feb 09, 2015 4:48 pm
    St. Johns, Michigan
Beautiful work Sam.
Pete
Pete
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
great looking work Sam.
real men need cups !
Barrett
    Wed Apr 19, 2017 8:05 pm
1.5" chromoly tubing joint. Any tips are appreciated
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Here's a random batch of pics from stuff I've been working on, I do post on my Instagram account a good bit of your interested. RNHFAB
1/2" sanitary
1/2" sanitary
Vertical up
Vertical up
All finished
All finished
    Sun Jan 15, 2017 1:08 am
Stuff from this weekImageImageImageImageImageImageImageImageImage
    Tue Dec 13, 2016 9:24 pm
    Clearwater Florida
5th Street Fab wrote:Stuff from this weekImageImageImageImageImageImageImageImageImage
AAAAAAAAAAAAAAAAAAAAAAAAAAAND now I remember why I never go to this thread :lol:
Good stuff Rick and 5th St.
motox
    Delaware
rick
beautiful job on the box corner!!!
ex framie
    Sun Aug 09, 2015 1:09 am
    Brisbane QLD Land of oz
I'm so inadequate.
Thanks guys.
Very nice work the pair of you.
Pete
Everyone, please remember... When you're looking at work that impresses you, work that makes you question your own, you are looking at goals. Objectives. The place you want to be with a few years' more experience.
NONE of these weldporn jockeys came out of the womb doing that, and every one has had their share of epic fails before they got consistent, and a few more before they were good.
NEVER put yourself down because your weld doesn't look like so-and-so's. If you're six months in, and he's been doing it 30 years, you can't expect to be on par.
jernigan78
    Thu Apr 20, 2017 4:20 pm
Aloha guys. Ill jump in on this. Some stuff from this week. Mostly fishing stuff. 316 stainless stuff. Mahalo
    near Chicago
Otto Nobedder wrote:Everyone, please remember... When you're looking at work that impresses you, work that makes you question your own, you are looking at goals. Objectives. The place you want to be with a few years' more experience.
And also realize..if you do the same thing every day you better damned well get or be good at it or you'll be down the road. It's the guys that have to wear all the hats that impress me 8-)
Rick_H
    PA/MD
Recycling an old filler bowl to make something else...
.065" tubing, .020" bowl
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
I love repurposing stuff. It means someone saw the potential in something that others would have trashed. Nice work Rick.
Sent using Tapatalk
nelson
    Sun Jul 17, 2016 1:21 pm
    near philly
I welded something by mistake thinking it's aluminum casting but it worked.... what the hell?
It's too heavy and fairly magnetic. The aluminum stuck....what is it?
nelson
    near philly
I can't post 2 pictures for some reason...
Pic
Pic
bruce991
    Tue Jan 05, 2016 10:31 pm
    Central Michigan
Made this smoker box for a friend this weekend. Adding legs right now. One heavy SOB 1/4 inch plate 22 by 14 inches. Putting a grate inside tomorrow.
Als smoker 2.JPG (54.34 KiB) Viewed 3044 times
Als smoker 3.JPG (47.37 KiB) Viewed 3044 times
Al smoker 1.JPG (64.4 KiB) Viewed 3044 times
