Dave
    Sat Nov 15, 2014 4:02 pm
    Chicago area
Before final fit up and I thought I was finished LOL
This is a project that I spent all last winter and spring on. If I only had the boat in the back yard. This was my first go at 316 stainless. That stuff is alive when you heat it up. I'm just a backyard hack and every louse thing I touch is a learning experience. I think I got it and the next project will go easier.
Finished!
Finished!
Bow Pulpit
Bow Pulpit
Before I killed it
Before I killed it
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
Gotta say that looks pretty sweet to me Dave - well done!
Kym
Dave
    Chicago area
MosquitoMoto wrote:Gotta say that looks pretty sweet to me Dave - well done!
Kym
Thank you Kym!
For my next trick I need to make an Arch for a 41 foot cigarette boat, I have a friend that wants a double arch with a ladder in it. now I have to go practice my aluminum skills or lack of LOL.
I need to get helium going I have a small tank and another regulator I just need to get the backpressure valves and the hoses, I saw the vid Jody did and it looks trick.
    The Land Down Under
Your own boat, yes Dave?
If you want to take a look at some awesome aluminium fabrication for boating applications, just search out some of TamJeff's posts. The guy is a genius.
Kym
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Yay finally complete and installed.
Man who lives in glass house shouldn't throw stones. :D good thing it wasn't glass. Nice finished product
Fe3c
    Sat Mar 12, 2016 11:32 pm
    Las Vegas
44 inches of tig welding 1/2 at a time across the bottom of the panel. 45 inches to go across the top.
Would be a better project for a mig but I'm a glutton for punishment.
Melt all the things.
VooDoo
    Mon Nov 11, 2013 10:54 am
    Finland
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Hey Rick, nice job. Bet you're glad to have that one finished in that awkward location.
Still lookin for the roll holder :)
Rick_H
    PA/MD
Coldman wrote:Hey Rick, nice job. Bet you're glad to have that one finished in that awkward location.
Yeah, glad it is done and installed, no one will appreciate the amount of work that went into that thing, the welding and frame was easy, those doors, latches, locks and hardware all took longer. I have about 30-33 hours in it and less then $1000 in material, hoist and latches, handles in the entire thing, outside contractor quoted $7700 with us suppling the lexan and hardware...I say I saved the company a a$$ load of money.
:mrgreen: ....we actually have a electrician that is "vertically challenged" we kept telling people it was his new office. :D
Rick_H
    PA/MD
Little alum machine part repair...
It was nice to weld something other then stainless...lol even if it was some dirty, coated aluminum.
    The Land Down Under
Nice job Rick.
How thick, and how many amps? Looks fairly meaty.
Kym
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
rick
did you have to do any welding on the back side?
Rick_H
    PA/MD
motox wrote:rick
It's 5/16" plate, I grooved out both sides...once I welded the front I grooved down until I hit my weld, then welded the other side up...she's solid now.
Not sure on amps, I had machine set to 250 and was using the pedal, when it puddled I dabbled 3/32" filler
motox
    Delaware
rick
figured as much but had to ask,,,,,
i know you are a master at repairs
and was curious if you had a trick
or reason for maybe only welding
one side...
Rick_H
    PA/MD
motox wrote:rick
one side...
Your too kind far from a master but I can get stuff done.
Probably could have gotten away with just once side, but figured what the hell..lol The part never had a gusset and we use to snap the 3/4" wide legs off about every 3 months. I welded the original gusset about 4 years ago, and we haven't broken an arm since. They mangled the one that was on there so I finally repaired this spare to replace the assembly, hope it lasts another 4 years.
nortical
    Mon Jun 20, 2016 9:06 pm
Couple of brackets for some fence infills gate and auto sliding gate I'm doing at the moment. All stainless steel!
On the phone at the moment so just rotate your head for the last one!
Rick_H
    PA/MD
Surprise stainless...lol
Coldman
    Oz
Beautiful work as usual.
Rick_H
    PA/MD
Coldman wrote:Beautiful work as usual.
Thanks buddy...
Here's some 303 (un weldable stainless, used 309l wire)
    Thu Dec 25, 2014 9:25 am
    near Chicago
Pretty welds there Rick. Looks like it behaved itself for you too. Never welded 303...any different from 304 or 316? Why the hell does your plant have that laying around anyway? Do you guys machine parts there?
Rick_H wrote: Here's some 303 (un weldable stainless, used 309l wire)
Rick, could have fooled me, looks like 304, I typically use 312 filler for 303. Below is an experiment I did some years back, the tube is 304 and the hex is 303, don't remember the filler but you can see the exaggerated undercut on the 303, it's as if the filler is trying to get away from the 303.
Rick_H
    PA/MD
exnailpounder wrote:Pretty welds there Rick. Looks like it behaved itself for you too. Never welded 303...any different from 304 or 316? Why the hell does your plant have that laying around anyway? Do you guys machine parts there?
Yes we do machine parts here as well, put we had one of our MRO suppliers that brought in 303 instead of 304 by mistake, so we have a few pieces of it in flat bar left around.
Rich-This actually behaved much better then it has in the past. It is not as bright as the 304 we typically stock, I've had it wear it barely welds at all...pisses you off a good bit. I was always told 309L with 303 to another metal...yeah that is pretty bad for sure, it does look like it doesn't want to mesh.
    Tue Jul 19, 2016 6:52 am
Made a little cold smoke generator from the idea on home brew forum http://www.homebrewtalk.com/showthread.php?t=320916
-Jon
Lincoln Viking 3350 K3034-2&3
Lincoln Power Mig 180c
hermit.shed on instagram
Rick_H
    PA/MD
Just a repair on a shelf they toss some bags and small drums of ingredients on before mixing/blending. The shelves only have one small piece of flat bar underneath and they keep flexing and breaking. So I decided to add some 1" x 1" square tube across the shelf to add some rigidity to it....works perfect. Also allowed me to straighten the shelves out.
