I'm just beginning my adventures in tig welding and was told by an ole timer to use 3-SMW filler rod (1/16 or 3/32) when I'm unsure of the properties. Just wondering what the welders out there think of this filler rod, it was the first time I had heard about this particular filler. Thanks in advance for your help.
Rj
From what I can tell, it isn't made as a tig filler anymore. I went looking for some a few weeks back and the only thing I came back with was stick electrodes. If you find someone selling it, post it here if you would.loadpin wrote:I'm just beginning my adventures in tig welding and was told by an ole timer to use 3-SMW filler rod (1/16 or 3/32) when I'm unsure of the properties. Just wondering what the welders out there think of this filler rod, it was the first time I had heard about this particular filler. Thanks in advance for your help.
Rj
-Sandow
-Charles Dickens
-Charles Dickens
Weldingsupply..comSandow wrote:From what I can tell, it isn't made as a tig filler anymore. I went looking for some a few weeks back and the only thing I came back with was stick electrodes. If you find someone selling it, post it here if you would.loadpin wrote:I'm just beginning my adventures in tig welding and was told by an ole timer to use 3-SMW filler rod (1/16 or 3/32) when I'm unsure of the properties. Just wondering what the welders out there think of this filler rod, it was the first time I had heard about this particular filler. Thanks in advance for your help.
Rj
-Sandow
Its expensive though. I only bought about $100 worth just to play around with.
Here is another LWS that has outlets everywhere and near me that can get the filler Rod, I didn't check to see what size rods they can supply. Hope this helps.
Airgas P/N HAR03SMW30
1/16" X 36" Harris® 3-SMW Maintenance Alloy TIG Welding Rod 10# Tube
Rj
Rj
