Yeah I didnt mean for you to go out and do critical parts. Just saying don't be afraid to try welding it. I personally like the way the puddle moves. I also like aluminum over regular mild steel too. I was worried about aluminum, but have really enjoyed working with it. prefer it over mild steel even. I need to start on titanium been gathering stuff to do it. thinking about making some TI parts for a project I got drawn up.dsmabe wrote:
Anyway, I've always believed if you're not comfortable with something, don't do it! You can always start small/ non critical, and work up to large scale/ critical parts.
dirtmidget33
- dirtmidget33
@GreinTime just wanted to see if it worked again.
jwright650
- jwright650
Thanks for sharing that video...the author makes some good points and explains the "why" behind the facts presented.dirtmidget33 wrote:a video that talks about it so here that is, and you guys can get info from some engineer instead of me spelling it out.
Welding 4130 CrMoly: http://youtu.be/ytSrEggjz1A
John Wright
Probably not going to be able to do it anytime soon but I would like to practice some 4130. With the different options that have been discussed, how much pre and post heat should be used?
It will probably be quite a while before I can do it but would like to weld several joints to see how they hold up to destructive testing.
I would like to try er70 and er 80, maybe some other fillers, all with no pre or post heat, some with just pre, some just post, and some pre and post heat!
You do know I linked a technical paper as to the results from exactly what you have described, right?dsmabe wrote:Probably not going to be able to do it anytime soon but I would like to practice some 4130. With the different options that have been discussed, how much pre and post heat should be used?
- GreinTime
