Hey , I'm doing my tig root pass with 1/8 filler metal and a 5/32 gap .Im feedeing the rod through top of pipe . Im running 80-85 amps and from 6-8 o clock the metal starts balling up . So I went side to side while feeding the rod and the metal balled up and dropped below radius of root pass .What should I do different?
Need Help
Waylin
waylinbrandon1
- waylinbrandon1
waylinbrandon1,
Here is a video that might help you out. Can you get some pictures up for us?
https://www.youtube.com/watch?v=UKaPIpxIneE
waylinbrandon1
- waylinbrandon1
waylinbrandon1
- waylinbrandon1
waylinbrandon1
- waylinbrandon1
Hey , the root pass im referring to is the one in front .The one with excessive penetration was one of a earlier try. Any advice is needed and appreciated . I structural weld but don't see pipe welders too often because I'm at the shop most of the time . So any advice is good.
keep welding
Waylin
keep welding
Waylin
Arizona SA200
- Arizona SA200
Arizona SA200
- Arizona SA200
waylinbrandon1
- waylinbrandon1
