New to TIG welding and I have a good bit of scrap aircraft grade material (4130 and 7075-T6) but would like to get a good bit of 5052 or 3003 plus some mild steel for practise. Local in Atlanta. Anyone reasonable in the area. Already called a couple of "Steel" places without much luck. Someone needs to "sell" a coupon kit for beginners. Thanks
You can often get decent deals on some drop from larger Steel Suppliers. Or, you might find a local Metal Supermarket branch near you. They too have small stuff. They’re franchises, so if you introduce yourself to the owner, make a deal to pick up their scrap, weld on it, then return it to them for salvage, it’s a win-win. You get practice material, they get it back weighing more!
- tungstendipper
Go to your local community college that teaches welding and asked them where they get their steel. Many will give you some coupons to weld with. While you're there, check-out their night courses.
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
Pricey, but Lincoln welding, www.JFLF.org has coupons for sale, at that address, "project kits" at the top of the page.
Lincoln Weld-Pak 180
Lincoln spool gun
Everlast PowerUltra 205p
AHP AlphaTig 200X
Assorted stuff
Lincoln spool gun
AHP AlphaTig 200X
Assorted stuff
- crashbandit
My local steel supplier has cut offs from larger orders, for $0.65/lb for steel and $2.25/lb aluminum I check them out the about once a month and basically pick up their leftovers.
HTP Invertig 221H w/ Arctic Chill cooler and CK20 torch
Lincoln MP210 -- SOLD
Optrel Crystal 2.0
Optrel Crystal 2.0
ROBERTINCREST
- ROBERTINCREST
cgaengineer
- cgaengineer
Try welding/fab shops...even here in Winder, GA we have many nearby.n3nman wrote:New to TIG welding and I have a good bit of scrap aircraft grade material (4130 and 7075-T6) but would like to get a good bit of 5052 or 3003 plus some mild steel for practise. Local in Atlanta. Anyone reasonable in the area. Already called a couple of "Steel" places without much luck. Someone needs to "sell" a coupon kit for beginners. Thanks
Go to weldmetalsonline.com, they all kinds of coupons and kits to practice with.n3nman wrote:New to TIG welding and I have a good bit of scrap aircraft grade material (4130 and 7075-T6) but would like to get a good bit of 5052 or 3003 plus some mild steel for practise. Local in Atlanta. Anyone reasonable in the area. Already called a couple of "Steel" places without much luck. Someone needs to "sell" a coupon kit for beginners. Thanks
