yhanie
    Mon Apr 16, 2018 5:09 pm
this is the machine that i used to weld aluminum.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
You can't use that machine for welding aluminium (very easily) as it is a DC mig/stick /tig. For learners and basic stuff you need an Ac/dc tig welder.
yhanie
hi mate,if cant use the machine to weld aluminum,can i use it for steel welding?
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
yhanie wrote:hi mate,if cant use the machine to weld aluminum,can i use it for steel welding?
yes its fine for welding steel.
yhanie
ok thanks mate,if i can use for steel this machine.can i use it also for stainless steel mate? i would be happy if i can use this machine :)
tweake
    New Zealand
its fine with stainless.
yhanie
for car exhaust mate what kind of stainless this one? is this machine is ok for welding stainless forexhaust.pls see attachment thanks
    Australia; Victoria
Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding. Aluminium requires AC cutting, the constant change of polarity is used to break down the aluminium oxide layer.
yhanie
ok mate thanks a lot for this one,,uve been helpful to me.ill try this machine to weld stainless steel.
Lightning
    Wed Aug 24, 2016 9:55 pm
weldin mike 27 wrote:Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding..
If you tig the stainless, you'll probably have a better outcome with DC electrode negative, though...
His statement was and steel can be TIG welded, plus the OP can weld anything set for DCEP. All DC TIG is set for DCEN, but the machine can also do DCEP.
    Australia; Victoria
Damn. Sorry fellas. DC electrode Negative is it. Need to proof read better.
