Typically gun steel is an A723 type steel. Check the characteristics of that steel, but the only thing I could think to be careful of is embrittlement after welding.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
tig is the process of choice for quite a few modern gunsmiths, the best reason i can see for this is the wide variety of filler/ fusion metals and the adjustability of the amperage (heat) put into the metal, this is especially important for hardened and case-hardened steels.....ALWAYS UNLOAD BEFORE WELDING....you probably knew that ,but it never hurts to repeat it.....(for the dumb-asses out there)
not bad~~O(∩_∩)O
_______________________________________
tiffany jewelry sale pandora charms sale cheap thomas sabo
