The old buzz box welds at 50 volts AC and the inverter welds at 70 volts DC, is it the cause ?
I did a test with both machines on the same conditions on a 2mm sheet metal and took this picture:
Rods:
Thanks for your reply Poland 308, i did that experiment, with the buzz box the slag went completely off after 1min, with the inverter i waited more than 10 min but only went off small parts of the slag, the remaining slag looks like black superglue. No matter how much i wait, it don't pop offPoland308 wrote:SS stick weld slag is notorious for coming off hard. Biggest thing is let cool and it will start to pop off all on its own, it’s designed to work like that. Until the weld is cool enough you will just fight it, if you tried to get it off when it was still hot then it usually looks like your pictures, and it almost makes it stick on there even worse. Maybe that’s just me.
I did that, 45, 40, 35, 30 amps... the problem remains. I've been searching the internet for answers, and i got to the conclusion that the high voltage might be the problem, my inverter welds at 70v, on the rod's box appears 50v on the description... but that's just assumptions, i need more information.tweake wrote:try dropping your amps a bit.
AC is a bit cooler than DC.
i take it you havn't put a meter on to check.Mvtepixels wrote:I did that, 45, 40, 35, 30 amps... the problem remains. I've been searching the internet for answers, and i got to the conclusion that the high voltage might be the problem, my inverter welds at 70v, on the rod's box appears 50v on the description... but that's just assumptions, i need more information.tweake wrote:try dropping your amps a bit.
tweake wrote: i take it you havn't put a meter on to check.
i doubt its 70v welding voltage. might be 70v ocv.
inverters are not as predictable in their welding voltage like transformer machines.
the ocv on the rod box relates more to transformer machines.
did you try increasing amps?
sorry i should have asked earlier.
unfortunately i have not stick welder stainless. i don't know if its sticking due to being to hot or to cold.
i'm wondering if transformer run voltage is a lot higher and actually getting a bit more heat at lower amps.
also what is your arc length like?
I never welded with 6010 or 6011, in Portugal it's a pain in the ass to find this rods, in my country the shops love 6013tweake wrote:i see esab actually list a weld voltage for those rods. to me at the moment it does seam to require a high run voltage.
so i wonder what the inverter welder is like running 6011?
if its got a cel or 6010 mode try it on that.
