Can aluminum be welded with an AC only stick welder?
Thanks for any help.
Jock
The short answer is,
Yes.
AC is apparently the preferred machine for the same reason high-frequency is used in TIG. It doesn't work well on material under 1/8".
If you google "aluminum SMAW", you'll find more than you ever wanted to know.
Steve
Yes.
Steve
I agree.
It falls into that category of:
"Just because you can doesn't always mean you should"
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
shouldershot
- shouldershot
The main thing I've learned about stick welding aluminum is to make sure you heat the material up enough before you weld it. It's the fastest you'll ever burn a rod up too.
