This is my first post on the forum, so bear with me...
I have started welding 5G 6 inch ID 40 wall pipe, with a 6010+++++ for the root and 7018 the rest of the way. The root pass is fine for me, but I have trouble with tons of slag in the toes of the hot pass. Any advise on this?
Thanks for your time,
-John Henry Utley
Henry Utley
- Henry Utley
The land is supposed to be 1/8 and the root opening is supposed to be 3/32. Land goes back and forth and root opening is usually a little wider.
Keep the land at an 8th and make sure the gap is 3/32. I use a /8 6010 at about 75-80 amps, depending on the welder. Then run the hot pass with no weave just a steady pull.
Henry Utley
- Henry Utley
the Test I took allowed for use of 3/32 or 1/8. But sch 40 pipe is so thin that it’s much easier to do with 3/32.
Edit
The test I took was for pressure pipe. Isn’t D1.1 for structural steel? There is probably a wps for your test. Any and all allowances and limitations are on that paper.
Edit
Henry Utley
- Henry Utley
- Farmwelding
ASME code?Poland308 wrote:the Test I took allowed for use of 3/32 or 1/8. But sch 40 pipe is so thin that it’s much easier to do with 3/32.
Edit
If it is for a job ever contact the test supervisor possibly?
D1.1 is AWS. ANSI
https://law.resource.org/pub/us/cfr/ibr ... 1.2000.pdf
Henry Utley
- Henry Utley
Its not for a job, I'm learning to weld in high school. I have been through open root stick, tig, and mig on plate but pipe is a whole different deal.
