AKweldshop wrote:Mbalone!!!!
Your totally ignoring my request!!
Throw those rods as far as you can throw them, then run out there and throw them even further!!
When they clump together like that, They will not run good!!!!
You have to run higher amperages and they stick, and get porosity!!
You'll never get anywhere with those rods!!
I'll give you the money to buy a new box.![]()
Fleetweld.
nyc7018 wrote:Not too bad at all. My first thought is that you should slow down a little.
Notice how your ripples are shaped like: <
They should be more like this: (
Id slow down a little and watch the back of the puddle. That will tell you how your beads are going to look.
If you cant go slower with a straight drag, try to go back and forth a little bit like this: wwwww
But not too dramatic. Keep it tight.
You look like your toes are tied in pretty well and try to overlap the previous bead by just less than half. All in all it looks like youre pretty close to putting out some really nice beads.
Great job documenting. Hopefully the veterans on this forum can help ya a little better than i can
AKweldshop wrote:So,
Its running way better right??
Nope.mbmalone wrote: I also changed where my ground attaches to my welding table, now I have it attaching on the far left corner. I weld left to right, so I am sort of welding away from the ground and I think it helps. Maybe it somehow pulls the puddle back?
nyc7018 wrote:here's some more ac/dc tombstone shots.
nyc7018 wrote:You look like your amps were fine. Just gotta work on manipulating that puddle.
AKweldshop wrote:My friend,
Hobart rods are junk to begin with, except a few certain alloy rods.
Please,
Head to a local welding store, and buy some premium Lincoln fleet wood rods.
I guarantee you will be amazed.
Those rods you have are old and dried out.
That's my advice for you right now.
Just for comparison sake... next time run 3 beads on 85. Then 3 on 90. Then 3 on 95. Or reverse the order. Whatever u want. But that should help u fine tune how u like it set for a certain rod in a certain position.
Otto Nobedder wrote:Nope.mbmalone wrote: I also changed where my ground attaches to my welding table, now I have it attaching on the far left corner. I weld left to right, so I am sort of welding away from the ground and I think it helps. Maybe it somehow pulls the puddle back?
But if it works for you...
AKweldshop wrote:Careful mate, quite the accusation calling me a pro....![]()
I'll let the pics say if I'm a pro or not.
Definitly within the week.
nyc7018 wrote:Looks a lot better. You had some nice ones in there and it looks like you slowed down. Youre making good progress keep it up
Stay as consistent as possible and watch that puddle. You stayed a lot straighter too.
Try some fillets or laps with 6010
AKweldshop wrote:I was starting to get leery of your welder having to rest a lot...
http://search.tb.ask.com/search/redirec ... D%3D&ord=0&
But I looked up the specs.
20% duty cycle, at 125 amps....
Pretty wimpy.
~John
Yeah those little guys get hot real fast on DC.AKweldshop wrote:I was starting to get leery of your welder having to rest a lot...
Pretty wimpy.
~John
But on AC you can run a real long time around 125-135 amps..
