I'm new to plasma cutting. I've found very little in the way of recommendations for settings.
Is the air pressure important for cutting or for cooling the torch or both? What air pressure works best?
Has anyone found an inexpensive source for S45 torch consumables? How often would a person expect to change the cup?
joe
It all depends on the type and thickness of metal you're cutting and the size of your machine (plasma cutter)
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
billyolds
- billyolds
ive only used a plasma a few times, most of them at school. Im sure like welders every machine is different but you want to tune the setting to minimize/eliminate the slag, my teachers called it kief but i cant find any info on anyone calling it that so i may remeber wrong.
heres a tips and tricks i found on google
http://www.thefabricator.com/article/pl ... -right-now
It is what it is...
I think the term is "kerf". That may help your search.billyolds wrote:ive only used a plasma a few times, most of them at school. Im sure like welders every machine is different but you want to tune the setting to minimize/eliminate the slag, my teachers called it kief but i cant find any info on anyone calling it that so i may remeber wrong.
