I was Father's Day gifted a CUT50F pilot-arc plasma cutter. Tried it out on some 1/4" material and wow. I've been requested to make some yard art figures. Looking online I was going to use 16ga. steel and make templates. My gun came with a bent wire standoff applied. I have read that if you take off this standoff and drag the tip it will cause premature wearing of the tip. I see many dragging the tip on the metal using templates. Is it OK to drag with this cutter?
Thanks,
Mike
Hopefully Jim will be along soon with more knowledge than I have on the subject - but from what I've seen the generic Chinese cut 50 or 60 use the AG60 torch - while cutting in straight lines is best done with the standoff - cutting shapes / templates etc is best dragged - couple of people I know had them & they don't see that dramatic a difference used either way - the consumable life is not great however you work the machine & if you order in good time just buy a good quantity from " Shop River " or your personal favorite Chinese Ebay seller ! they are not that expensive - accept it's a small price to add to a job - I think from memory they have a slight cross milled on the cutting face ( which is usually only done on the cheap nozzles if they expect it to be used as a drag tip )- if you make this more pronounced it helps with nozzle life - just remember they eat themselves away from the inside anyway & having air that's not clean & dry will cost more nozzle life than dragging - hope this helps.
That makes sense. We primarily use Thermal Dynamics Cutmaster 80 at work, and while it comes with cut guides, and even a specific drag tip, I find on 16 ga. stainless, for example, I can drag the standard tip directly on the metal for a cleaner more precise cut at 50 amps or less.mbg wrote:Thanks - that was very helpful. Since my post, don’t know if it’s good info but they said if you were below 40 amps dragging is ok.
Mike
Steve
- tungstendipper
I love the trees!!!!
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
Wow - puts me to shame. Love that design!
Here is my first attempt. Found out that using 3/8" ply the pilot arc tip is the same distance from the work piece as the wire standoff provided (about 1/8"). I did some trials to dial it in with short straight cuts and all the spark spray was well behaved below the piece. When I went to the real thing lots of spray till I really slowed it down. Normal? Or am I doing something wrong? (Ha, or both):
Edited - after following suggestions I cranked up the amperage and I can cut not only faster but more smoothly with natural motion. Even though it’s more amps I think it’s less work in the machine because at lower amps and slow speed I was able to trip the overload. No so with higher amps.
Mike
Mike
