I am retired and a metal working hobyist. I am not a welder, but I can stick metal together without it looking like a mud dobber nest (I am old, and my hands are not steady.) I mostly use a Lincoln MIG welder with flux cored wire, only occasionally use MIG. I just purchased a Lotos plasma cutter/TIG unit and am attempting to learn TIG (hard, not going well.) I primarily build equipment and accessories to help me maintain our property.
- Marc Godwin
Welcome young timer, you are only as old as you feel,
This is the best place to pick up any tips you will ever need and you will find the vast experience available is unique.
If your hands are a bit shaky just find yourself a better prop position or adjust your welding stool to suit whatever position you find yourself in.
Marc. Aussie on the loose
- Braehill
There's always the trusty Tig Finger. Gotta support the big guy so we can keep swappin' bull. Filling each others heads with more dross.
Besides shaking gives the weld a little character.
You're not old, just seasoned.
- Marc Godwin
pjgent wrote:I am retired and a metal working hobyist. I am not a welder, but I can stick metal together without it looking like a mud dobber nest (I am old, and my hands are not steady.) I mostly use a Lincoln MIG welder with flux cored wire, only occasionally use MIG. I just purchased a Lotos plasma cutter/TIG unit and am attempting to learn TIG (hard, not going well.) I primarily build equipment and accessories to help me maintain our property.
Mate,
Suggest you look at Jody's bead drills for steel, and aluminium they will help you emensly, I watched them over and over. Particularly watch the tungsten gap to puddle.
When you first are learning tig the biggest problem is tungsten contamination. Now when I started I got sick of grinding tungsten clean or cutting and regrinding
- Marc Godwin
Sorry mateOtto Nobedder wrote:SHUSH!!!
If my wife thinks chocolate is involved, I'll have to teach her to weld!
