Farmwelding wrote:Welcome aboard mate! What machine did you get?
Thank you! I got a dynasty 280dx with water cooler. I have also gotten the wired foot pedal and the classic series mask. For the torch, I went with a local generic brand instead of a miller torch, because the miller torch didn't have the on/off switch on the torch and so couldn't be used without a pedal. I'll report on my experience using it, but I wish I could compare it to a miller torch and see if there is a difference. Here is the torch I have received:
http://www.vegamak.com/vegamak/tr/torcl ... veg_18.php
I have done a lot of oxy acetylene gas welding mild steel before, and I have been told that the feel for gas welding helps a lot with TIG welding. I am really curious to see how true that is
I have also attempted to do gas welding on aluminum, but no matter how many different fluxes I have tried for that, I just couldn't get a satisfactory weld result. It's really hard getting information about the flux technical details here, the sellers sure don't know them
so it was trial and error and I finally gave up.
My first use for this machine will be welding the segments and bushings of a scissor lift that I have been building. All mild steel. Next will be a CNC for PCB drilling, where I will use thick aluminum for rigidity and accuracy.
