ecQr_yUBnM8
and part 2
QHxIaouv_wA
Big thanks to JD for letting me film this build
Good video's, I don't work with the big fab projects like JD does, have in the past, but do like to watch how he fabricates.
Also by cutting the splice plates to fit over the rec tubing it doesn't change the over all length
Was curious why such a short section had to be spliced?
- snip_20170913152910.jpg (60.6 KiB) Viewed 5808 times
Richard,
If you noticed, the video only shows 40' of the 60' build. I think the short section is shown with an extension (10''?) not shown in the video, at the far left of the "assembled outside" image. There also seems to be a bolt-up on the last 10' section on the right.
Speculating, for lack of image quality.
Steve
Steve
- Wood Welder
He used a Lincoln 256 with flux core/c25 but I know JD has a Lincoln 210 MP. Is the 210 MP capable of the same welds? Obviously the duty cycle would limit the number of welds per hour.
I really enjoy watching JD's work.
Lincoln 100 amp transformer MIG w/flux core wire
HF TIG w/no pedal for steel & stainless, Stick w/3/32 6011,7018
Formerly: Victor O/A and Lincoln 225 AC buzz box
Looking to upgrade
Bikes-XR250, CRF230
Looking to upgrade
Bikes-XR250, CRF230
Yes, he uses it in the field and talks about it in other videosWood Welder wrote:He used a Lincoln 256 with flux core/c25 but I know JD has a Lincoln 210 MP. Is the 210 MP capable of the same welds? Obviously the duty cycle would limit the number of welds per hour.
- Wood Welder
I wonder if that would be maxed-out on the 210mp. He sure does lay down a substantial amount of metal in a single pass with the 256.LtBadd wrote:Yes, he uses it in the field and talks about it in other videosWood Welder wrote:He used a Lincoln 256 with flux core/c25 but I know JD has a Lincoln 210 MP. Is the 210 MP capable of the same welds? Obviously the duty cycle would limit the number of welds per hour.
In answer to your question. If you enlarge the aerial shot at the end of the video, it looks like the rebar rack is built in three sections for ease of transport, so the short vertical section you see was added onto with two more bays.
There's a rebar yard near me and this project looks like an infeed or outfeed rack for the hydraulic guillotine that chops the rebar. The yard has an overhead crane like JD's but much larger and outdoors that covers the whole yard loading and unloading trucks. Rebar is stored on simple racks close to the ground and they have two guillotines set up. Only the office is indoors. I needed to go there recently to pickup some 1/2" type "W" low carbon weldable rebar for some anchors to embed in concrete block which I stick welded with 3/32" 6011 to 1/4" plate with multiple passes to build up a large fillet on each rebar where they butted into the plates.
Looking to upgrade
Bikes-XR250, CRF230
Looking to upgrade
Bikes-XR250, CRF230
By looking at the 210 specs, it'll run .045" cored wire, so should run .035 just fine without too much worry of hitting the duty cycle, I'm guessing. He (JD) speaks highly of the unit in his videos with Jody.Wood Welder wrote: I wonder if that would be maxed-out on the 210mp. He sure does lay down a substantial amount of metal in a single pass with the 256.
