- ldbtx
Determining what is the "proper tool for the job" depends entirely on what the job is. Many times a torpedo level is the right tool, sometimes you might need a transit or a laser level or maybe just a longer bubble level. Tell us a bit more about what you're working on and I'll bet somebody here can get you pointed in the right direction.
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
If you are simply checking for level, use the longest one you can fit on your work piece. Sometimes a torpedo level is as big as you can get. I've got a little 2" level, torpedo levels, a 2', and a 4' long one for the bigger jobs. I've even taken the body of my combo square off and used the level in that if it fits.
Adapt and overcome.
Adapt and overcome.
- ldbtx
That Smart Tool is a good looking device. Bit pricier than the digital level that I use at work for aligning our 32" telescope to zenith. When it's time to do polar alignment on the scope, I forget about the digital and use a machinist's level that's accurate to, if I remember right, 0.0005" / 10". Polar alignment is critical when you're aiming at a star that's light years away.
Again, the right tool for the job varies with the job...but I've never regretted any money I spent on top quality tools.
Miller Bobcat 225
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
