I just started tig welding at work, and I have no problem running simple fillet welds, but I am having trouble doing open root joints, I am getting porosity almost every time on the root pass, I get plenty of penetration on the back from what I can see and the weld isn't "sugaring" on the back, I can't seem to figure it out, help would be greatly appreciated.
On a butt weld, you need more gas coverage, so a slightly higher flow, bigger cup and also less tungsten stick out. That's can cause air to be sucked in.
