wish i could weld
    Sun Nov 02, 2014 6:02 pm
HI, Is there a quick reference video that shows bad welds and what caused them.
I have to spend lots of time looking for the video I think has the answer to my results.
Thanks for the help.
Welcome!
I'm not aware of a specific video for that, but I don't doubt it exists.
This is a unique community, where you can post pictures of "what went wrong" and ask questions, where no one will "flame" you for your efforts.
I'm going to move your topic into the "general shop talk" category, where everyone will see it.
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
wish i could weld wrote:HI, Is there a quick reference video that shows bad welds and what caused them.
I too would like to see a video along the lines of "cause and effect" where we can see something wrong, why it was wrong and how to fix it. Jody has tips sprinkled throughout his videos already so it will be hard to single one of them out.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
what process. mig? jody has a video series on basic mig settings and what to do to achieve good welds. if its stick search jodys "welding with bubba" for stick tips.
wish i could weld
It was tig on aluminum. The first few inches were fine and then it sooted up and quit puddling.
dirtmidget33
    Tue May 13, 2014 5:22 pm
There is chucke2009 on YouTub that did a video similar to that. Don't believe it was about aluminum but just TIG on steel been awile since I seen it.
TIG Weld Troubleshooting: Common Problems & Solut…: http://youtu.be/CVAByfuZXIY
    Australia; Victoria
Kevin Caron does instructional vids. He's a good guy but he's been hanging out with with MR tig lately so who knows.
soutthpaw
    Thu Sep 18, 2014 12:14 pm
    Albuquerque NM
weldin mike 27 wrote:Kevin Caron does instructional vids. He's a good guy but he's been hanging out with with MR tig lately so who knows.
Heh, I wondered what was up with that too. ..
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
You guys are relentless.
    Australia; Victoria
I think Kevin is a great bloke, honest and never ever overstates his ability or knowledge. Haven't watched any of his latest videos , so I have no idea what the collaboration videos are like. Maybe he thought that other dude a few things.
wish i could weld wrote:It was tig on aluminum. The first few inches were fine and then it sooted up and quit puddling.
Two things come to mind immediately.
First is that your gas flow is dropping as you progress (or you're changing the torch angle as you progress). Aluminum likes a lot of gas flow relative to steel (30-35 cfh is not uncommon for a standard collet, 20-25 for a gas-lens), and at these higher flows the puddle is more sensitive to torch angle.
Second, note how far you pull the rod back from the puddle after adding filler. Aluminum is really sensitive to this. The rod builds heat as you progress, just like the parent metal, and if you pull the rod outside the shielding gas it oxidizes immediately, so the next dip carries that crap to your puddle. It doesn't take too many repeats of this to get enough crap in the puddle to disrupt your weld.
A third possibility is that your HF circuitry is mis-behaving as it warms up, but I consider this unlikely. Usually, it either works or doesn't.
The more information you can give us, the closer we can get to the root of the problem.
    Sat Oct 25, 2014 2:21 pm
    Toronto, Ohio
In my limited experience, sooty looking beads are related to gas coverage.
Check out my journey through welding school https://www.youtube.com/channel/UCJWQmJ ... aTma2q31Qg
    Australia; Victoria
As Steve said, the hi- freq could not be functioning correctly. Or may just be set so start instead of continuous as Ac requires constant to function.
