holding small steel
Posted: Tue Feb 13, 2024 2:38 pm
by mpete53
Holding small pieces at odd angles has always been a problem for me. I am have made a proof of concept magnetic fitting for a magnetic dial indicator holder. While the one I made was on a 3D printer is very heat sensitive it does work. Just some food for thought one of you may find a better way to do it.
IMG_4561 r.jpg (52.2 KiB) Viewed 21850 times
Re: holding small steel
Posted: Wed Feb 14, 2024 12:33 am
Depending upon the strength of the magnet (and its proximity to the weld) it can aggravate a TIG arc in my experience. Might not be such a problem for a quick tack though.
Posted: Wed Feb 14, 2024 12:41 am
by tweake
i usually use the strong hand magtabs.
Posted: Wed Feb 14, 2024 10:48 am
by mpete53
I have the stronghand magtabs and the work fine most of the time, but this is gust another option.
Posted: Wed Feb 14, 2024 4:15 pm
by BillE.Dee
As Cj stated, magnets interfere with tig welding and I've had magnets interfere with mig welding. When I need extra hands, I use a "third hand" that I put together using a connecting rod from Caterpillar engine and pieces of 1/4 inch round stock. Nothing fancy but gives me that extra support.
Posted: Wed Feb 14, 2024 8:50 pm
by Coldman
Magnets do interfere with the arc but it's kinda fun to drag the arc back to where you need to tack.
Posted: Wed Jul 17, 2024 12:33 pm
by metalmagpie
I can usually hold it "pretty close" and get 1 small tack on it, then adjust from there. It's pretty easy to bend one small MIG tack.
Posted: Thu Sep 19, 2024 3:49 pm
by Timmy_Tiggs
That looks like a good solution. For me, the hardest thing is clamping something that is curved. Clamps want to slide off.
I had to make a jig for this job:
