I am new to the forum and have questions about welding aluminum. I have been torch, arc and mig welding for years but I have never welded aluminum. I find myself needing to now learn and am wondering about equipment. My primary machine is a Lincoln DC250 with an LN7 wire feeder that dates back to the early 80's. I have talked to Lincoln and was told that a spool gun cannot be adapted to the LN7. I have been around long enough to know that almost anything is possible with the assistance of Walt Disney's mouse. For what I need to do I believe that a spool gun is my best choice but I do not want to purchase another machine because for what I need to do it will be more cost effective to pay someone to do it than to do it myself. I would rather do it myself if I can modify my present equipment as it is probably not the last time that I will need to weld something aluminum.
What about the low temp aluminum soldering rods? The current project is a small tank that needs to hold less than 20 psi of pressure. I have never tried to use them and am curious about the learning curve.
Got Lumens?
- Got Lumens?
Yes the low temp rods would be the least expensive if the tank were not under pressure.oldguy44 wrote:I am new to the forum and have questions about welding aluminum. I have been torch, arc and mig welding for years but I have never welded aluminum. I find myself needing to now learn and am wondering about equipment. My primary machine is a Lincoln DC250 with an LN7 wire feeder that dates back to the early 80's. I have talked to Lincoln and was told that a spool gun cannot be adapted to the LN7. I have been around long enough to know that almost anything is possible with the assistance of Walt Disney's mouse. For what I need to do I believe that a spool gun is my best choice but I do not want to purchase another machine because for what I need to do it will be more cost effective to pay someone to do it than to do it myself. I would rather do it myself if I can modify my present equipment as it is probably not the last time that I will need to weld something aluminum.
AC is used in TIG/MIG welding aluminum. Also a Helium/Argon mix for gas helps.
