EEEEEWWWWWW!!!!!!
I loved the one place I worked, I got 4 hours of overtime in almost every night just by sitting around and shooting the breeze with my boss and his family and be his DD.Superiorwelding wrote:Oh well then it never hurts to get paid to do things for yourself/stuff you wanted done.Otto Nobedder wrote:I mis-communicated a bit... I did stay eight hours. And got eight hours of work done. However, I got that eight hours of work done in about five, allowing time for the other stuff I fit in...
Steve S![]()
Matt
Matt
Last edited by Superiorwelding on Mon May 19, 2014 10:43 pm, edited 1 time in total.
That sounds like it'd be fun to try a 6g although I'd have to mig it all the way as my tig or stick skills wouldn't suffice my stick would be atrocious right about now lol my mig might not be much better in that position lol
Tomorrow morning, I'm going through the 9600 PSI pressure test (and switch setting) with the engineers. Today I set up all the blinds and the test safety-relief. In the morning, I'll be setting up the high-pressure pump, the nitrogen supply for the pump, and a 6000 PSI nitrogen bottle for the initial pressurization.Otto Nobedder wrote:The x-ray truck shows up tomorrow at 8AM.
I get to take 8 hrs. overtime just to be there for it.
I'd better damn pass....
I do "hydro-testing" (pneumpatic ASME retest, not actually hydro) all the time, but this pressure level will be a first, and by a wide margin.
Should be an experience. I get to work with an engineer I've not worked with in a few years, who's company I enjoy.
They are like hens teethJDIGGS82 wrote:Blasphemy an enjoyable engineer! Just kidding
JK
Steve,Otto Nobedder wrote:Tomorrow morning, I'm going through the 9600 PSI pressure test (and switch setting) with the engineers. Today I set up all the blinds and the test safety-relief. In the morning, I'll be setting up the high-pressure pump, the nitrogen supply for the pump, and a 6000 PSI nitrogen bottle for the initial pressurization.Otto Nobedder wrote:The x-ray truck shows up tomorrow at 8AM.
The best of luck to you. If you can, would you document and take pictures of how you do your test tomorrow. I would like to know the details if you can share them or have the time.
I know I would be nervous testing at that pressure. I might (but doubt) get to TIG weld 2" pipe that will see 2000psi working pressure and I am looking forward to it.
Jonathan,
I had no opportunity to photograph today, as the boss was too curious. However, on this go, we only went to 8400 to set a pair of control switches, and the main reason I was involved, apparently, is I'll be doing the full pressurization on my own, AFTER a line is replaced whose pressure rating is too low for the system. The pump discharge line is rated for 7850 psi, as I recall, making 8400 to over-pressure test limit. This line will be replaced (by me) with a 3/4" line with the 10 kpsi rating, and THEN we'll go to full pressure. I worked with the engineers today so I know the weak points in the system, what to watch for, and what risks to mitigate. No one was surprised that I didn't take notes, it was pretty straightforward and logical to me.
Seems our gas-booster pump is rated for 9kpsi, so I'm not sure how they intend to go 9600... unless they plan to over-pressure it. We'll see what the final word is.
On the plus side, they'll keep everyone away during the pressure test, and I should be able to shoot pics at will.
One benefit to working with engineers... We were set up outside for everyone's safety... in the blazing sun. They ran to home depot and bought a tarp and rope to build a sun shade!
I look forward to any information you can provide us. Most of what I pressurize is only to 5 psi to check for leaks, mainly fuel tanks so 9600psi is quite a difference.Otto Nobedder wrote:Jonathan,
One benefit to working with engineers... We were set up outside for everyone's safety... in the blazing sun. They ran to home depot and bought a tarp and rope to build a sun shade!![]()
Yes engineers can be nice at times but it the other 95% of the time that gets you
What, no pictures?JDIGGS82 wrote:I got some tig practice in today not a good day I was trying to walk the cup but after trying it appears I was drunkenly stumbling the cup lmao
I will say, during (before) the 8400psi test, there was strict diligence to LOTO. All valves that should be in a certain position were locked out in that position. The test was done outside in an area no one had any business in unless connected to the test, so we didn't bother taping off the area, but I'm sure if we'd been in the shop, this would have been done, too.
The only parts of the system that had not previously seen proof pressure were the new valve, and the welds I attached it with, so there was not much concern with bursting failures. By agreement, we modified one aspect fo the procedure on the fly... We considered the posibility of the pump discharge check valve abruptyly failing, and pressurizing the pump inlet piping (3" sch. 10 wouldn't respond well to being pressurized into the thousands of pounds, so we opened a locked-out valve, an inlet valve, and a connection point cap to allow a path for very rapid discharge. That's just part of the process, though... analyzing what might go wrong, sorting out the possible consequences, and finding ways to protect from them.
I chucked that damn thing in the scrap bin was frustrated maybe I'll dig it out tomorrow morning and snap a few lolSuperiorwelding wrote:What, no pictures?JDIGGS82 wrote:I got some tig practice in today not a good day I was trying to walk the cup but after trying it appears I was drunkenly stumbling the cup lmao![]()
To explain why everything I weld on this unit is x-rayed and over-pressured before it's released, I offer the following picture of a "weld" cut from this trailer two years ago. Scary stuff on a system that is supposed to pump pure hydrogen gas to 8000 psi on a regular basis.
If you use your imagination...
I can see a soldier wading into the surf, arms upraised, as a wave breaks over his head...
This unit was supposed to have been x-rayed 10%. We called in a team to x-ray 50 welds chosen at random, and got 50 fails.
ROTFLMAO!!!Braehill wrote:I can see it now that you mention it and I'm guessing by the raised arms that he's French.![]()
- Braehill
I guess I should be careful that I don't piss half of your neighbors off. I'm thinking French jokes don't go over well in your neck of the woods.
Naw... Instead of midwest Pollack jokes, or Minnesota "Sven and Ole" jokes, We have Boudreaux and Thibideaux jokes.Braehill wrote:I guess I should be careful that I don't piss half of your neighbors off. I'm thinking French jokes don't go over well in your neck of the woods.
It's all good, wherever you're from!
Not even the Cajuns consider themselves French.
- Braehill
It was all good til the thumb sucking, belly aching, cry babies came around with 'political correctness" and told us how we should talk to one another. I've worked with people of all different backgrounds and we busted each others balls about whatever came to mind and we all had fun at each others expense, and at the end of the day you went home as freinds. Now we have to watch what you say so nobody gets offended, like it's a right not to be offended, but I degress.
It's not my fault the Swedes never got the jokes....
