ryanjames170
- ryanjames170
some i have a prety stupid question here but what would happen if a person put a cold cut saw blade in your average wood chop saw?
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
Klutch Plasma 275i Plasma Cutter
Hobard/Smith Oxy Torch using propane.
RM Fab & Products
- MosquitoMoto
Running blades rated for one speed in a machine rated for another is always a bit iffy.
Never mind the space time continuum, there are worse things you could rip a hole in!
Kym
Kym
sedanman
- sedanman
The cut parts on a dry saw don't get hot but the chips do. The wood saw is likely not built to deal with the very hot stream of metal chips. Wood saws also typically lack clamping mechanisms for the stock.
No problems at all
Given you match the speed and clamp well.
I run my circular Bosch saw with Evolution blade. Last week I cut 8 mm steel like nothing.
Did a bunch of 13 sheets of roof steel once. Saw handled it better than my legs that recieved the "stream"
Tom Osselton
- Tom Osselton
Just wondering if you could use a dimmer switch hooked to a outlet to control the speed like I do for my gas furnace.
ryanjames170
- ryanjames170
that would be a idea, i only realy need to make cuts in angle and such and is kinda pain to cut good with a pasma, im kinda on the fence of what i should buy as i kinda dont have the cash to get a cold cut type saw.. i could only realy spring for a wood or abrasive type saw..Tom Osselton wrote:Just wondering if you could use a dimmer switch hooked to a outlet to control the speed like I do for my gas furnace.
Welder/Fitter
RM Fab & Products
RM Fab & Products
sedanman
- sedanman
Wood saw plus a metal blade is about as much as a dry saw. If you have a Home Depot card, order the Evolution 380 through their website and take 6 months to pay it off with no interest.
There are two issues with using a dry-cut metal blade in a saw not made for it.
The first has been mentioned, RPM. The dry saws (a cold saw is liquid cooled/lubricated), like a lathe or drill press, work best at a certain RPM and feed rate for the material. I don't recommend a simple "dimmer switch" in this application... A light bulb is a constant load while a saw is varying with your feed rate. They do make motor speed controllers that are quite similar but are designed for varying loads.
The blades are extremely hard and stiff, and over-revving them is a dangerous thing. Our Metal Devil at work advises running a new blade with no load and the guard closed for a full minute before making a cut to preclude a failure from a flaw.
This brings up issue #2... How tough is the guard on the saw you intend to use it on? Are you certain it's tough enough to contain a blade that shatters like glass but weighs significantly more?
I'm not going to tell you whether you can or should. I just want to be sure you're weighing the risks.
Use a router speed control, built to take 15 amperes or more. These are triac voltage controllers and work by chopping off part of the sine wave. Noisy as ever with the sharp cutoff but brushed universal motors, they don't care. They run fine on DC if you have enough voltage since field and rotor are series wound.Tom Osselton wrote:Just wondering if you could use a dimmer switch hooked to a outlet to control the speed like I do for my gas furnace.
ryanjames170
- ryanjames170
I ended up bitting the bullet and buying a Evo Rage 3 saw i know its limited to 1/4 inch but its also able to do Wood and steel with miter cuts so killed 2 birds with one stone and also has a 11 3/4 wide cut capacity
Welder/Fitter
RM Fab & Products
RM Fab & Products
I've used that one, and it's nice. I went with the 14" Rage 2.ryanjames170 wrote:I ended up bitting the bullet and buying a Evo Rage 3 saw i know its limited to 1/4 inch but its also able to do Wood and steel with miter cuts so killed 2 birds with one stone and also has a 11 3/4 wide cut capacity
ryanjames170
- ryanjames170
Go look up the evolution rage 3..sedanman wrote:Wood saw plus a metal blade is about as much as a dry saw. If you have a Home Depot card, order the Evolution 380 through their website and take 6 months to pay it off with no interest.
Welder/Fitter
RM Fab & Products
RM Fab & Products
Poleframer
- Poleframer
The problem with the "dimmer switch" is that you would be decreasing the current available and reducing the power as well as the speed. It would be like taking your foot off the gas pedal instead of gearing down climbing a hill under load in a truck.
