I don't know if this has been posted here before, but I found it pretty interesting to watch. MIG welding recorded with a high speed camera at 10,000 frames/sec. There are a few of stick welding in there as well if you look around the playlist.
https://youtu.be/UFFSJ1G4vsg
https://youtu.be/je8VghtYo5o?list=UUTMx ... nEnLY686Bg
Sort of mesmerizing.
that is amazing that the arc itself is as erased on some videos , so we mostly see the way the metal drip to the puddle.mpete53 wrote:great to see that is really happening
Pianos , restorer and tuner
Dedicated to learn welding since april
slowly learning
not complaining of doing beads and beads
pro inverter PROGYS 200 FV PFC CEL+tig lift
OA Oxyflam 1000 cutting and welding gas torch
slowly learning
richard parker
- richard parker
I find it pretty interesting how in the second link above, you can see the flux on the rod slowly being consumed while the balls of molten metal shoot out from inside it to join the puddle. Amazing how they manage to filter out the light of the arc to get these shots.
Some other interesting videos in the list there, exploding firecrackers, attacking owls, and such.
